Add devices
Hi.
I have a question about adding devices. This goes with my Motorola Netopio… model number I can’t remember… 7iergendwas-44…not! When I called the support
I was told that this was not going. However, this is the case with the Centro Grande. However, it is necessary to unlock the function via Telnet, etc.
I wonder…is it possible that you are so attached to Swisscom devices?
I have the Casa Trio and would only like to use other devices…I know myself quite well with computers, routers and configurations, but I am very cautious because of the Swisscom pre configurations etc.
What do you mean? What are your experiences? Does anyone also have the Casa Trio and does not use the Swisscom Router modem?
I’m assuming the support got you wrong.
Maybe you didn’t say you understood enough for the Spopport?
And I suppose you’re still talking about connecting devices to WLAN?
This is steadfastly activated so that you only have to enter the WLAN access code.
Just plug in and finish the LAN.
  • nova13 has responded to this post.
    [unknown]
    Glass ball?
    and I assume that other LAN subscribers in the internal client list are from the GUI, to which you can refer, for example, to Portforwardings.
    Perhaps the surgery soon solves the mystery, then we can put the glass ball aside
    gruss.
    ….keep on rockin' 🤘🏼🤘🏼🤘🏼
    [unknown]
    Of course, certain devices have to assign a specific IP.
    But you don’t need a router with DHCP.
    You can manually assign IP addresses outside the DHCP area on the devices.
    And if I’m quite out of mind, can you also assign an IP to a MAC Motorola?
    [unknown]
    Not at all. And otherwise the support man has been bad because he has logged into a “simulation” of my router to see the menu structure. He confirmed that there is no possibility from “Swisscom” page.
    I can already assign an IP to the devices. But I want to forgive this in the router so that the MAC address imm gets this IP.
      Here we go. However, neither the Motorola nor the Swisscom version of the Pirelli via the GUI. These settings must be done via shell.
