Malfunction of the router part of the centro grande pirelli
Good morning,
Since the installation of this router provided by swisscom (vdsl obliges), I have had problems with the router part of this device, forcing me to periodically turn it off and on again so that it can find the connected devices on the network in fixed IP or dhcp.
Is this problem known? Is there a more reliable modem router because I am often away and the router can transmit images from a surveillance camera.
Hello Sam10,
Can you detail how your installation is carried out please? Do you use cables, WiFi, switches or other devices? So that we can check the settings of your router, please also provide us with your contact details by private message.
Cordialement
Centrogrande Router
Netgear switch powering axis camera, unifi wifi access points, printers, etc.
Connection via a patch panel on swisscom Tv
I will send you my contact details by pm
13 days later
Good morning,
A bit of the same problem I imagine following the change of platform following the transition to TV2.0, I went from a centro piccolo to Grande. Only problems with the latter, frequent resynchos, reboots, very poor quality to the point of no longer being able to watch TV.
I put the picollo back, which is more stable (but the phone no longer works ;-))
