There is now a box with 4x RJ45 there from a former ISDN installation. The U port is connected to the IB. The 3 other sockets (1x S-Bus, 2x from) have no function and nothing is connected internally.
@kaetho wrote:
I think that if you check the cable from the UP to the socket or replace it with a new cable, you will probably get even better values.
I’ll have to follow up with the management. Apartment building from the mid-80s.
Can the UP be found at the house entry or in the apartment entry (T+T cover)? From the T+T socket to the socket with the U-port, where I plugged in the IB, it’s about 10m - probably U72 or I51 cable. How can I distinguish between the two cables and which is better? Can these 10m make so much difference compared to the several 100m up to the DSLAM?
@kaetho wrote:
The calibration phase actually begins with the highest possible profile and is then reduced/levelled down to the best profile (as quickly as possible with as few errors as possible).
Are you sure about that? Is there (still) a calibration phase when changing subscriptions/tariffs?
Thanks to you in the meantime - greetings, Jürgen
….keep on rockin' 🤘🏼🤘🏼🤘🏼
