Hi,
It seems that you didn’t enter your wifi router password in AirTies Air 4400 wifi repeater.
Password has to be entered to AirTies Air 4400 wifi repeater, than it should work fine.
How to do so:
1. Conect your PC to AirTies Air 4400 wifi repeater with RJ45 cable.
2. In any internet browser go to: 192.168.1.1 and login into AirTies Air 4400 wifi repeater with default password.
Userid: admin
Password: password
3. Select your router and enter your wifi password.
After a while white lamp shoud stay permanently on, what means that AirTies Air 4400 wifi repeate is working well.
btw. I recomend yo to install inSSIDer from:
http://download.cnet.com/inSSIDer/3000-18508_4-10848357.html
Relja
